Cisco Linksys WAG120N. Как прошить?
ICE_Alex
21 Окт 2012
Здравствуйте. Проблема с Cisco Linksys WAG120N. При включении мигает индикатор питания. Подключил JTAG кабель, лог загрузки модема внизу. Невидет лан-кабель и не пингуется. Думаю что дело в прошивке, помогите прошить его через COM-порт.
ROM VER: 1.2.0
CFG 04
EEPROM Data OK
U-Boot 1.1.5-2.0 (Jul 22 2009 - 14:05:20)
relocate_code start
relocate_code finish.
Flash: 4 MB
amazon_se_spi_init success!!
Using default environment
In: serial
Out: serial
Err: serial
Net: Internal Clock
SET_CLASS_A_VALUE = 1.
Selected EPHY_MODE
AMAZON_SE Switch
mac = c8:d7:19:bc:21:4d
BUTTON = 1
Type "run flash_nfs" to mount root filesystem over NFS
Hit any key to stop autoboot: 0
## Booting image at 00030000 ...
Image Name: MIPS Linux-2.4.31-Amazon_SE-3.6.
Created: 2010-08-06 6:07:42 UTC
Image Type: MIPS Linux Kernel Image (lzma compressed)
Data Size: 577077 Bytes = 563.6 kB
Load Address: 80002000
Entry Point: 801b2040
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
Starting kernel ...
MC_PRIO = 0x0 -> 0xc0
flash_start=0x0
flash_size=4194304l
CPU revision is: 0001906c
Primary instruction cache 8kB, physically tagged, 4-way, linesize 16 bytes.
Primary data cache 8kB, 2-way, linesize 16 bytes.
Linux version 2.4.31-Amazon_SE-3.6.10.4.patch.3-R0416V36_BSP_SPI_FLASH_A4 (root@localhost) (gcc version 3.3.6) #4
Fri Aug 6 14:07:33 CST 2010
Can't analyze prologue code at 8001d9f0
Determined physical RAM map:
User-defined physical RAM map:
memory: 02000000 @ 00000000 (usable)
On node 0 totalpages: 8192
zone(0): 8192 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/mtdblock5 ip=192.168.1.1:192.168.1.2::::eth0:on console=ttyS0,115200
ethaddr=c8:d7:19:bc:21:4d mem=32M panic=1
ethaddr_setup: mac address c8-d7-19-bc-21-4d
mips_hpt_frequency:133333333
r4k_offset: 00145855(1333333)
Using 133.333 MHz high precision timer.
[ifx_asc_init_hardware 1081]: ASC ID = 0x101044c4
[ifx_asc_init_hardware 1083]: TxFIFO size = 16, RxFIFO size = 16
[ifx_asc_init_hardware 1085]: TxFIFO CON = 0x1f01, RxFIFO CON = 0x1f01
Calibrating delay loop...
266.24 BogoMIPS
MIPS CPU counter frequency is fixed at 133333333 Hz
Memory: 30300k/32768k available (1709k kernel code, 2468k reserved, 108k data, 92k init, 0k highmem)
Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
Checking for 'wait' instruction... unavailable.
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
amazon_se_dma_init
dma_chip_init
LSP Revision 1
Starting kswapd
devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
Squashfs 2.2 (released 2005/07/03) (C) 2002-2004, 2005 Phillip Lougher
pty: 256 Unix98 ptys configured
ttyS%d0 at MEM 0xbe100c00 (irq = 66) is a IFX_ASC
Infineon Technologies Synchronous Serial Controller (SSC) driver version 0.2.1
Amazon_SE MEI version:2.04.00
cgu: misc_register on minor = 63
amazon_se_gptu_init:<6>gptu: totally 6 16-bit timers/counters
gptu: misc_register on minor 62
gptu: succeeded to request irq 25
gptu: succeeded to request irq 26
gptu: succeeded to request irq 27
gptu: succeeded to request irq 28
gptu: succeeded to request irq 29
gptu: succeeded to request irq 30
cgu_get_fpi_bus_clock(2) = 133333333, clock_divider = 1
bus clock = 5000000, clock_divider = 1
divider = 33333332
set_timer(0, 4000), divider = 33333332
request_timer(0, 0x0000010D, 33333332)
reload value = 33333332
led: misc_register on minor = 151
Infineon CPE API Driver version: DSL CPE API V3.20.5.1
PPP generic driver version 2.4.2
amazon_se ETOP driver loaded!
Internal Clock
Selected EPHY_MODE
oamk: init_module() called.
Opening oam kernel socket
oamk: init_module() returned.
ppe: ATM init succeeded (firmware version 1.1.0.2.1.13)
[init_amazon_se_mtd 438]: AMAZON_SE_EBU_CON 0x40000060, AMAZON_SE_EBU_CON0 0x1d7fd
init_amazon_se_mtd: start_scan_addr: a0000000
init_amazon_se_mtd: chip probing count 0
Amazon_se: probing address:a0000000
Amazon_se: No support flash chips found!
Infineon Technologies Synchronous SPI flash driver version 0.0.1
MTD driver for SPI flash.
Probing for Serial flash ...
Creating 7 MTD partitions on "amazon_se-spi":
0x00000000-0x00010000 : "U-Boot"
0x00010000-0x00020000 : "ENV_MAC"
0x00030000-0x00400000 : "ROOTFS_KERNEL"
0x00020000-0x00030000 : "NVRAM"
0x00030000-0x000d0000 : "KERNEL"
0x000d0000-0x00400000 : "ROOTFS"
usb.c: registered new driver hub
dwc_otg: version 2.40a 10-APR-2006
DWC_otg: Using DMA mode
dwc_otg_hcd: irq 31, addr be101000
usb.c: new USB bus registered, assigned bus number 1
hub.c: USB hub found
hub.c: 1 port detected
DWC_otg: Init: Port Power? op_state=1
DWC_otg: Init: Power Port (0)
dwc_otg proc initialization okay!
pegasus.c: v0.4.32 (2003/06/06):Pegasus/Pegasus II USB Ethernet driver
usb.c: registered new driver pegasus
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 2048 bind 4096)
Linux IP multicast router 0.06 plus PIM-SM
ip_conntrack version 2.1 (256 buckets, 2048 max) - 368 bytes per conntrack
tuple->src.u.port[0]=517
tuple->src.u.port[1]=518
ip_conntrack_pptp version 1.9 loaded
ip_conntrack_rtsp v0.01 loading
ip_nat_pptp version 1.5 loaded
ip_nat_rtsp v0.01 loading
ip_tables: (C) 2000-2002 Netfilter core team
netfilter PSD loaded - (c) astaro AG
ipt_random match loaded
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
NET4: Ethernet Bridge 008 for NET4.0
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
Amazon_Se Port Initialization
VFS: Mounted root (squashfs filesystem) readonly.
Mounted devfs on /dev
init started: BusyBox v1.00 (2010.08.06-03:28+0000) multi-call binary
new_init_action:action=1
Starting pid 13, console /dev/ttyS0: '/etc/rcS'
Algorithmics/MIPS FPU Emulator v1.5
Using /lib/modules/led.o
led module init ...
create_proc_entry push_button
get led data for such gpio
after init semaCreated character device /dev/amazon_se-port with major[253] and minor[0]
Created character device /dev/dsl_cpe_api with major[107] and minor[0]
Created character device /dev/ifx_mei with major[105] and minor[0]
<6>device eth0 entered promiscuous mode
br0: port 1(eth0) entering learning state
Using /lib/modules/rt3052_iNIC.o
RT3052iNIC: 802.11n WLAN MII driver v2.0.0.0 (April. 6, 2009)
===> Sync Mac with MII master
============= Init Thread ===================
RacfgTaskThread pid = 83
RacfgBacklogThread pid = 84
Org bridge hook = 80170f08
Change bridge hook = c0038ab0
ra0: Ralink iNIC at 0x0, c8:d7:19:bc:21:4d
iNIC Open ra0
Op mode = 1
BssidNum=1
Wait for boot done...
ff
100
200
br0: port 1(eth0) entering forwarding state
br0: topology change detected, propagating
timeout(30 secs): cmd=0000 no response
ERROR! can't get target's MAC address, boot fail.
=========== RaCfgRestartiNIC begin =========
===========iNic_reset=========
Op mode = 1
BssidNum=1
Op mode = 1
BssidNum=1
Op mode = 1
BssidNum=1
ff
100
200
Op mode = 1
BssidNum=1
Unhandled kernel unaligned access in unaligned.c::emulate_load_store_insn, line 492:
$0 : 00000000 1000fc01 81048ce8 00000002 80217360 00000000 ba2e8ba3 00000000
$8 : 386d4513 0000fc00 00000000 00000002 fffffffb 00000000 00000002 ffffffff
$16: 81a79000 819f6540 00000000 819f6540 819f6598 00000001 00000000 00000004
$24: 00000000 2ab978e0 819f6000 819f6448 00000000 8004d24c
Hi : ffffb095
Lo : 00001a79
epc : 8004d2e8 Not tainted
Status: 1000fc03
Cause : 10800010
PrId : 0001906c
Process if (pid: 86, stackpage=819f6000)
Stack: 80048a3c 819f6540 80217360 81a242e0 81048ce8 819f6540 80217360
81a242e0 00000001 80049788 80217360 819f64c0 81a79005 0000000d 819f658d
0000000b 6d7188ff 801738f0 81a242e0 819f65a8 819f6540 819f6578 00000001
819fc160 819f6540 00000000 80049938 819f65a8 801eb9b0 8001d808 801eae40
8001d908 80049b24 80049b0c 00000000 80019844 819f6570 84c6e9cf 00000000
81c6b000 ...
Call Trace: [<80048a3c>] [<80049788>] [<801738f0>] [<80049938>] [<8001d808>]
[<8001d908>] [<80049b24>] [<80049b0c>] [<80019844>] [<8004a094>] [<801738f0>]
[<80019220>] [<8003ba9c>] [<80181e60>] [<801738f0>] [<800e1f08>] [<8002aeb4>]
[<80181e84>] [<8017391c>] [<c002d704>] [<8001d908>] [<c003bcb4>] [<c00395e0>]
[<80019220>] [<80003e2c>] [<80013f9c>] [<80184244>] [<8001401c>] [<80014160>]
[<80014638>] [<80014414>] [<80014200>] [<c002e888>] [<c002f454>] [<80014200>]
[<c002e7fc>] [<c0039ada>] [<80014200>] [<c002eaf0>] [<80014200>] ...
Code: 8c430014 10600006 00000000 <c0620028> 24420001 e0620028 1040fffc 00000000 ae230004
Unhandled kernel unaligned access in unaligned.c::emulate_load_store_insn, line 486:
$0 : 00000000 1000fc00 00000001 00000002 81e6d620 1000fc01 00000066 81059cfc
$8 : 81059d0c 1000fc01 801d8bc4 00002000 81048dc4 8100001c 8100001c 0000034f
$16: 81e6d620 80189444 819f6000 0000000b 819f6598 00000001 00000000 00000004
$24: 00000007 819f6227 819f6000 819f62e0 00000000 80017c54
Hi : 00000000
Lo : 00000013
epc : 80074838 Not tainted
Status: 1000fc03
Cause : 10800010
PrId : 0001906c
Process ---- (pid: 86, stackpage=819f6000)
Stack: 819f6598 800122cc 00000000 00000004 81e6d620 80189444 80017c54
80017c4c 819f6000 819f6328 00000000 80007ec4 80189434 80189444 819f6398
819f6540 80007edc 80007ed4 7ff80000 00000001 00000001 00000000 81a79000
819f6398 0000000a 80007f04 7ff80000 7ff80000 7ff80000 7ff80000 000001ec
7ff80000 8000b3d4 7ff80000 7ff80000 7ff80000 7ff80000 7ff80000 000001ec
7ff80000 ...
Call Trace: [<800122cc>] [<80189444>] [<80017c54>] [<80017c4c>] [<80007ec4>]
[<80189434>] [<80189444>] [<80007edc>] [<80007ed4>] [<80007f04>] [<8000b3d4>]
[<80006bb0>] [<8004d24c>] [<8004d2e8>] [<80048a3c>] [<80049788>] [<801738f0>]
[<80049938>] [<8001d808>] [<8001d908>] [<80049b24>] [<80049b0c>] [<80019844>]
[<8004a094>] [<801738f0>] [<80019220>] [<8003ba9c>] [<80181e60>] [<801738f0>]
[<800e1f08>] [<8002aeb4>] [<80181e84>] [<8017391c>] [<c002d704>] [<8001d908>]
[<c003bcb4>] [<c00395e0>] [<80019220>] [<80003e2c>] [<80013f9c>] ...
Code: 8f850294 10a00023 00000000 <8ca4001c> 28830000 24827fff 0083100a 00021bc3 000313c0
__down_read-139 sem = 0000001d
Kernel unaligned instruction access in unaligned.c::do_ade, line 564:
$0 : 00000000 1000fc00 00000023 00000000 00000001 0000000f 00000000 00000000
$8 : 00000001 00003844 00002001 00000000 fffffffe 00000010 00000001 ffffffff
$16: 80189434 819f6000 0000001d 0000000f 00000001 819f6008 00000001 00000004
$24: 00000001 819f5e59 819f6000 819f5f50 00000000 8000c770
Hi : 00000006
Lo : d5555563
epc : 80028028 Not tainted
Status: 1000fc02
Cause : 10800010
PrId : 0001906c
Process -- (pid: 4446424, stackpage=819f4000)
Stack: 2f696663 6f6e6669 67207261 30207570 00555345 523d726f 6f740048
00030001 2f006574 68616464 723d6338 3a64373a 31393a62 633a3231 3a346400
5445524d 3d767431 30320050 4154483d 2f62696e 3a2f7362 696e3a2f 7573722f
7362696e 3a2f7573 722f6269 6e006970 3d313932 2e313638 2e312e31 3a313932
2e313638 2e312e32 3a3a3a3a 65746830 3a6f6e00 5348454c 4c3d2f62 80189434
819f60e8 ...
Call Trace: [<80189434>]
Code: 27bd0020 10800020 00003021 <8c860008> 10c00009 00000000 8cc20008 00a2102b 10400005
__down_read-139 sem = 0043e184
Unable to handle kernel paging request at virtual address 0043e170, epc == 80028028, ra == 8000c770
Oops in fault.c::do_page_fault, line 226:
$0 : 00000000 1000fc00 00000023 00000000 0043e168 0043e170 00000000 00000000
$8 : 00000001 00003f70 00002001 00000000 fffffffe 00000010 00000001 ffffffff
$16: 0043e168 819f4000 0043e184 0043e170 0043e168 819f40f8 00000000 00000004
$24: 00000005 819f3f4d 819f4000 819f4040 819f5dc8 8000c770
Hi : 00000000
Lo : 2aaaaaab
Status: 1000fc02
Cause : 50808008
PrId : 0001906c
Process (pid: 0, stackpage=819f2000)
Stack: 004458c8 004698c0 0044de58 004698c8 0043d988 004698d0 0043e168
00030001 0044d1ec 004698e0 0044e010 004698e8 0043ac04 004698f0 0044e868
004698f8 0044de58 00469904 0043d8d8 0046990c 004478b0 00469914 00447718
0046991c 0044e724 00469924 0044c7d0 0046992c 34383165 33349934 0043f6ec
0046993c 0044f0e8 00469944 801db288 00005f2d 00005f4d 0043e170 0043e168
819f4000 ...
Call Trace: [<8000eef4>] [<8001401c>] [<801833ec>] [<8000c770>] [<80028028>]
[<8000eef4>] [<8001401c>] [<801833ec>] [<8000c770>] [<80028028>] [<8000eef4>]
[<8001401c>] [<801833ec>] [<8000c770>] [<80028028>] [<8000eef4>] [<8001401c>]
[<801833ec>] [<8000c770>] [<80028028>] [<8000eef4>] [<8001401c>] [<801833ec>]
[<8000c770>] [<80028028>] [<8000eef4>] [<8001401c>] [<801833ec>] [<8000c770>]
[<80028028>] [<8000eef4>] [<8001401c>] [<801833ec>] [<8000c770>] [<80028028>]
[<8000eef4>] [<8001401c>] [<801833ec>] [<8000c770>] [<80028028>] ...
