kapral30
Анша Абдуль братья
- 1 Ноя 2013
Не работает Tor браузер
Уже раз 20 переустанавливал, не работает. Полоска доходит до средины и всё так и висит. Никакой защиты кроме доктора веба на компе нету. Всякие защитники винды отключены, так-же в докторе вебе отключён слежение за интернетом. К роутеру подключены 2 компа оба на вин 8.1. На одном тор работает прекрасно на втором нет. Скажите в чём может быть дело?
ЛОГ ошибки.
14.06.2015 17:37:56.846 [NOTICE] Opening Socks listener on 127.0.0.1:9150
14.06.2015 17:37:56.846 [NOTICE] Renaming old configuration file to "C:\Users\MR.KAPRAL\Desktop\Tor Browser\Browser\TorBrowser\Data\Tor\torrc.orig.1"
14.06.2015 17:37:57.507 [NOTICE] Bootstrapped 5%: Connecting to directory server
14.06.2015 17:37:57.788 [NOTICE] Bootstrapped 10%: Finishing handshake with directory server
14.06.2015 17:37:58.591 [NOTICE] Bootstrapped 15%: Establishing an encrypted directory connection
14.06.2015 17:37:58.858 [NOTICE] Bootstrapped 20%: Asking for networkstatus consensus
14.06.2015 17:37:59.125 [NOTICE] Bootstrapped 25%: Loading networkstatus consensus
14.06.2015 17:38:04.698 [WARN] Received directory with skewed time (server '199.254.238.52:443'): It seems that our clock is behind by 1 hours, 3 minutes, or that theirs is ahead. Tor requires an accurate clock to work: please check your time, timezone, and date settings.
14.06.2015 17:38:04.698 [NOTICE] I learned some more directory information, but not enough to build a circuit: We have no usable consensus.
14.06.2015 17:38:05.350 [NOTICE] Bootstrapped 40%: Loading authority key certs
14.06.2015 17:38:06.220 [WARN] Received directory with skewed time (server '193.23.244.244:443'): It seems that our clock is behind by 1 hours, 3 minutes, or that theirs is ahead. Tor requires an accurate clock to work: please check your time, timezone, and date settings.
14.06.2015 17:38:06.220 [WARN] Our clock is 21 minutes, 55 seconds behind the time published in the consensus network status document (2015-06-14 11:00:00 UTC). Tor needs an accurate clock to work correctly. Please check your time and date settings!
14.06.2015 17:38:06.220 [NOTICE] I learned some more directory information, but not enough to build a circuit: We have no recent usable consensus.
14.06.2015 17:38:16.680 [NOTICE] Closing no-longer-configured Socks listener on 127.0.0.1:9150
14.06.2015 17:38:16.680 [NOTICE] DisableNetwork is set. Tor will not make or accept non-control network connections. Shutting down all existing connections.
14.06.2015 17:38:16.680 [NOTICE] Closing old Socks listener on 127.0.0.1:9150
ЛОГ ошибки.
