Песенка про ёжика (не давать учить детям!!!)
  • Автор темы Автор темы AlexZir
AlexZir
support
Команда форума
19 Авг 2007
The Hedgehog Song, v1.7
Reconstructed by Matthew Crosby and alt.fan.pratchett
from the Discworld novels by Terry Pratchett
Bestiality sure is a fun thing to do
But I have to say this as a warning to you:
With almost all animals, you can have ball
But the hedgehog can never be buggered at all.
CHORUS 1: The spines on his back are too sharp for a man
They'll give you a pain in the worst place they can
The result I think you'll find will appall:
The hedgehog can never be buggered at all!
Mounting a horse can often be fun
An elephant too; though he weighs half a ton
Even a mouse (though his hole is quite small)
CHORUS 2: The spines on his back are so awful thick
you'll end up with naught but a painful prick.
He has an impregnable hole when curled up in a ball,
Hence the hedgehog can never be buggered at all!
Screwing a cow while she goes moo-moo
Will be entertaining to both her and you
Or you might try a tiger, if you have enough gall
CHORUS 3: (So here's to the hedgehog, he's sharp as they come
You'll never get through his impregnable bum
With his nose up his arsehole and rolled in a ball
The hedgehog can never be buggered at all)
CHORUS
A fish is refreshing, although a bit wet
And a cat or a dog can be more than a pet
Even a giraffe (despite being so tall)
CHORUS
You can manage a snake, though its poison might kill
It's amazing how humping a camel will thrill
You can go with a snail if you slow to a crawl
CHORUS
You can ravish a sloth but it would take all night
With a shark it is faster, but the darned beast might bite
We already mentioned the horse, you may recall
CHORUS
You can roger a skunk if you can stand the smell
Or even an oyster, should he let go of his shell
A troll can be rocky if down you should fall
CHORUS
For slippery fun, you can cornhole an otter
Or pego a pig after parting his trotters
Or tumble a tapir, though the prospect appall
CHORUS
For prosimian fun, you can bugger a lemur
To bolster your name as a pervert and schemer
The lemurs cry "Frink!" as a coy mating call
CHORUS
Antipodean pranks -- you can futter a wombat
Or strive with a 'roo in venereal combat
Or hump a goanna -- go on, do it all
CHORUS
A moose is amusing, a squid quite confusing
Or try on a rhino if you fancy a bruising,
Or mountin' a mountain goat (careful, don't fall!)
CHORUS
You could thrust with a thrush if you fancy a climb,
Or pork a few piglets if you have the time,
A skinhead's pet cat if you don't mind a brawl,
CHORUS
A sheep that's named 'Flossy' is warm you shall see,
You can try with a wasp, you can try with a bee.
You can hump with the dog that sleeps in the hall,
CHORUS
A lion is frisky, a leopard is fun,
But to keep up with them you may have to run.
You'll be liked by the fleas at the flea-market stall,
CHORUS
A hippo is funny but take care if underneath,
A pirhana is pleasant but watch out for his teeth.
Get a rodent, they can be found in the mall,
CHORUS
You tail-lifting buggers from Ramtop or plain
If you take my advice you will save yourself pain
When the base urges strike you it's best to recall
That the hedgehog can never be buggered at all
CHORUS
Your hedgehog's a handful and cute as a bun
You'd think he'd be perfect for animal fun
But hatpin-like pubic hairs prove to us all
That the hedgehog can never be buggered at all.
CHORUS
You can top a giraffe if you stand on a stool
Though a Jack Russell might make you look like a fool
But the fact still remains that if you want to ball
The hedgehog can never be buggered at all.
CHORUS
You can hump a baboon if it doesn't hump you
And a wildebeest's really got something quite gnu
Carouse with a louse if your weenie is small
CHORUS
It's hard with a crab 'cause its bum's watertight
The best way is sideways, then twist to the right
If you screw one, be thankful as shorewards you crawl
[FONT=&quot]For the hedgehog can never be buggered at all. [/FONT]
Фу, ну и похабень! Лёш, а при чем тут Терри Пратчетт и его Плоский мир?
Это его стихотворение, во всяком случае, в переведенной версии его фамилия как автора.
А, припоминаю. Это по линии Нянюшки Ягг.
Для тех, кто не в ладах с английским, даю перевод с гуглевого транслейтора.
Зоофилия уверен, это весело, что нужно сделать, но я должен сказать, это как предупреждение для Вас: С почти всех животных, вы можете иметь мяч Но еж никогда не может быть содомией вообще. Припев 1: шипы на спине слишком острые для человека они дадут вам боль в худшем месте, они могут Результат я думаю, вы найдете будет потрясать: Ежик никогда не может быть содомией вообще! Монтаж лошадь часто может быть весело слон слишком, хотя он весит полтонны Даже мышь (хотя его отверстие довольно небольшой) Но еж никогда не может быть содомией вообще. Припев 2: шипы на спине так ужасно толстая вы в конечном итоге с ничего, кроме болезненного укола. Он имеет неприступную отверстие, когда свернувшись в клубок, Следовательно еж никогда не может быть содомией вообще! Резьбовых соединений корову в то время как она идет Му-му Будет интересно, чтобы и ее и тебя Или вы можете попробовать тигра, если у вас достаточно желчь Но еж никогда не может быть содомией вообще. Припев 3: (Так вот, чтобы ежом, он острый, как они приходят Вы никогда не будете получать через его неприступной заднице С его носа до его засранцем и проката в шаре Ежик никогда не может быть содомией вообще) Припев рыбы освежает, хотя немного влажный И кошка или собака может быть больше домашнего животного Даже жираф (несмотря на то, так высок) Но еж никогда не может быть содомией вообще. Припев Вы можете управлять змею, хотя его яд может убить Просто удивительно, как толчки верблюда взволнует Вы можете пойти с улиткой, если вы медленно ползти Но ежа никогда не может быть содомией вообще. Припев Вы можете изнасиловать лень, но это займет всю ночь с акулой это быстрее, но чертовски зверь может укусить Мы уже упоминали лошадь, вы можете вспомнить Но еж никогда не может быть содомией вообще. Припев Вы можете Роджер скунс, если вы можете выдержать запах или даже устрицу, он должен отпустить его оболочки тролль может быть скалистая если вниз, вы должны упасть Но еж никогда не может быть содомией вообще. Припев Для скользкой веселья, вы можете Cornhole выдру Или Pego свиньи после расставания его рысаки Или падать на тапира, хотя перспектива потрясать Но еж никогда не может быть содомией вообще. Припев Для полуобезьяна веселья, вы можете ****к лемура, чтобы поддержать ваше имя как извращенца и интриган лемуров крик "Frink!" как застенчивый вызова спаривания Но ежа никогда не может быть содомией вообще. CHORUS Antipodean шалости - Вы можете Futter вомбат Или стремятся с «кенгуру в венерической бою Или горб Goanna - пойти на, делать все Но еж никогда не может быть содомией вообще его. Припев лося Забавно, кальмары довольно запутанным Или попробуйте на носорога, если вы представляете себе кровоподтеки, Or Mountin 'горный козел (осторожны, не упасть!), Но еж никогда не может быть содомией вообще. Припев Вы могли толкаете молочницы если вы представляете себе набор высоты, или свинины несколько поросят, если у вас есть время, любимая кошка скинхедов, если вы не возражаете потасовку, Но еж никогда не может быть содомией вообще. Припев овец, который назван "Flossy 'теплая, вы увидите, Вы можете попробовать с осой, вы можете попробовать с пчелой. Вы можете горб с собакой, который спит в зале, Но еж никогда не может быть содомией вообще. Припев лев резво, леопард это весело, но чтобы не отставать от них вы, возможно, придется работать. Вы будете нравиться блох на блошином-рыночных прилавках, Но еж никогда не может быть содомией вообще. Припев бегемота интересное, но позаботиться, если внизу, pirhana приятно, но следить за зубами. Получить грызуна, они могут быть найдены в торговом центре, но еж никогда не может быть содомией вообще. Припев Вы хвост подъема педерастов из RAMTOP или просто Если взять мой совет вы сэкономите боль Когда основание настоятельно призывает ударить вас лучше вспомнить, что еж никогда не может быть содомией вообще Припев Ваш Еж горстка и мило, как пучок You "подумать, что он был бы идеальным для животных веселья Но булавку, как лобковые волосы доказать нам всем, что еж никогда не может быть содомией вообще. Припев Вы можете пополнить жирафа, если вы стоите на табуретке Хотя Джек Рассел может заставить вас выглядеть дураком Но факт остается фактом, что если вы хотите, чтобы мяч Ежик никогда не может быть содомией вообще. Припев Вы можете горб бабуин, если она не горб вы и гну действительно получил что-то совсем GNU кутить с вошь, если ваш препона небольшой, но еж никогда не может быть содомией вообще. Припев Трудно с крабом Потому водонепроницаемой Лучший способ ее задницу является боком, затем поворот направо Если вы винт один, быть благодарными, как к берегу вы обход ежа никогда не может быть содомией вообще.
Так гораздо веселее! :))
И это я ещё похабник, значится :))
Ладно, вот несколько окультуренный авторский перевод, найденный в свободной библиотеке phantastike.ru, но от этого не менее смешной
Терри ПРЭТЧЕТТ
Песня про Ёжика
Можно трахнуть медведя суровой зимой, Когда мишка в берлоге храпит под сосной. Не советую этого делать весной, Ну, а ёжика вовсе не пробуй, друг мой.
Можно трахнуть коня, можно трахнуть осла, (Пони жалко: уж больно лошадка мала), Жеребца ломового (тут сила нужна), Только с ёжика, брат, не возьмёшь ни рожна.
Можно трахнуть быка (с высоты сундука), И лису, если верить словам знатока, Кое-кто говорит, можно трахнуть жука, Только ёжика, братцы, не трахнешь никак.
Энтомолог сказал - можно трахнуть осу, Герпетолог сказал - и змею (на весу), Можно трахнуть любую зверушку в лесу, Только ёжика - нет, заруби на носу.
Можно трахнуть слона (тут стремянка нужна И матрас, для того, чтоб, упав со слона, Уцелела спина - высота не страшна!) Только ёжика трахнуть нельзя ни хрена.
Можно трахнуть кота (это просто мечта!), Можно кролика трахнуть, из шляпы достав, Можно трахнуть дельфина и даже кита Только с ёжиком выйдет одна маета.
Если ты так удал, поезжай-ка в Непал, Трахни йети, что водится в Кхумбу-Гимал, Я охотно признаю, что ты экстремал Лишь бы ёжика, парень, ты трахать не стал.
Если чем-то тебе приглянулся удав, Я навряд ли скажу, что ты круто не прав. Можно трахнуть жирафу, забравшись на стол, Только с ёжиком выйдет - буквально - прокол.
Можешь трахать макак (не скажу тебе, как) Индюков и коров, поросят и собак, Утконоса, коль скоро ты редкий чудак Только ёжика трахнет лишь круглый дурак.
Можно ёжика стукнуть, а можно и пнуть, Можно тросточкой ёжика в пузико ткнуть, Можно в ёжика из револьвера пальнуть, А о том, чтобы трахнуть - и думать забудь.
[FONT=&quot]И в конце трудового тяжелого дня, Трахнув тигра, летучую мышь и слепня, Ты воскликнешь устало: "Ну, что за фигня! Этот долбанный ёжик затрахал меня![/FONT]
Ну ребята! Буду все-таки считать это интересом к поэзии а не к теме..
Геннадий :))
