15.7.2009
Проект ISO
15:24:38 #1 Text 0 File SCSIPTICommands.cpp, Line 403
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
15:24:38 #2 Text 0 File Isodoc.cpp, Line 6494
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
15:24:38 #3 ISO9660GEN -11 File geniso.cpp, Line 3312
First writeable address = 0 (0x00000000)
15:24:38 #4 Text 0 File Burncd.cpp, Line 3316
Turn on Disc-At-Once, using DVD media
15:24:39 #5 Text 0 File DlgWaitCD.cpp, Line 281
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2148751 (477:30.01, 4196MB)
15:24:39 #6 Text 0 File DlgWaitCD.cpp, Line 293
Write in overburning mode: NO (enabled: CD)
15:24:39 #7 Text 0 File DlgWaitCD.cpp, Line 2616
Recorder: Optiarc DVD RW AD-7170A, Media type: DVD-R
Disc Manufacturer: SONY16 - D1
Disc Application Code: 64, Disc Physical Code: 193
15:24:39 #8 Text 0 File DlgWaitCD.cpp, Line 459
>>> Protocol of DlgWaitCD activities: <<<
15:24:39 #9 Text 0 File ThreadedTransferInterface.cpp, Line 814
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2148752 (2148752) = #2148752/477:30.2
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2148752 blocks [Optiarc DVD RW AD-7170A ]
15:24:39 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1013
Prepare recorder [Optiarc DVD RW AD-7170A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4400644096, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2148752 | lead-out | 1 | 0x41 | 0x00
15:24:39 #11 Text 0 File SCSIPTICommands.cpp, Line 208
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
15:24:39 #12 Phase 24 File dlgbrnst.cpp, Line 1685
Caching of files started
15:24:39 #13 Text 0 File Burncd.cpp, Line 4158
Cache writing successful.
15:24:39 #14 Phase 25 File dlgbrnst.cpp, Line 1685
Caching of files completed
15:24:39 #15 Phase 36 File dlgbrnst.cpp, Line 1685
Burn process started at 4x (5*540 Кб/с)
15:24:39 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2717
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
15:24:39 #17 Text 0 File DVDR.cpp, Line 2846
Recording mode: Sequential Recording Mode for Multisession
15:24:39 #18 Text 0 File DVDR.cpp, Line 3002
Start write address at LBA 0
DVD high compatibility mode: Yes
15:24:39 #19 Text 0 File Cdrdrv.cpp, Line 8737
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 2FE10 h
Start sector number of the next Border-In: 2FFA0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
