Проблема с OpenGl
Стас23
28 Янв 2010
Проблема с запуском игры, помогите пожалуйста
Wolf 1.32 win-x86 May 1 2002
----- FS_Startup -----
Current search path:
d:\Program Files\Return To Castle Wolfenstein 7 in 1\tye\sp_pak8.pk3 (314 files)
d:\Program Files\Return To Castle Wolfenstein 7 in 1/tye
d:\Program Files\Return To Castle Wolfenstein 7 in 1\main\pak0.pk3 (7689 files)
d:\Program Files\Return To Castle Wolfenstein 7 in 1/main
8003 files in pk3 files
execing default.cfg
couldn't exec language.cfg
execing wolfconfig.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
Bypassing CD checks
----- Client Initialization -----
Cmd_AddCommand: map_restart already defined
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using colorsbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD( 16, 24, 0 )
...35 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
что это такое?
игра старенькая, спасибо что хоть кто то ответил. Называется Return To Castle Wolfenstein
вот скачал целую линейку их с инета такая со всеми проблема
Не плодите, пожалуйста, посты. Все можно уместить в одном. Модератор.
Как же, помню, играл...
Интересно, на каком компе игра запускается? Процессор, видеокарта и т.д. Возможна проблема с несовместимостью ОС если дело происходит на Висте. Или требуется обновление драйверов видеокарты.
так может кто помочь с моей проблемой?
А ты ответы читаешь? :) Или только спрашиваешь?
как можно точнее определить в чем проблема? может сказать данные какие?
Офигеть! Разговор глухого со слепым. :D Думаешь ответ из принтера выползет?
Я же спросил уже.
селерон 2,56. видео карта FX geforse 5700LE
ссори не привык еще к форумам, я ж говорю первый раз
А ОСь какая?
операционная система XP Home Edition
Драйверы видео обновлял? Игра старая, можно попробовать запустить в режиме максимальной совместимости.
сори Xp профес servise park 2 за 2002 год
я не знаю как их обновить.
как обновлять страницу, чтобы текст сообщения не печатать?
Валерий, это в диспетчере задач на видео адаптере правой кнопкой и обновить да?
стас -жми ф5 для обновления страницы (если правильно понял тебя). и пожалуйста не плоди посты.
спасибо, но когда ждать ответ? обновление видюхи в диспечере задач , да? не чего не будет ? операц не навернется? я просто не соображаю в этом , а поиграть очень хочется
киньте ссылку как и где можно обновить видео карту Geforse FX 5700LE
кто ниб знает как поставить режим совместимости
Загрузка драйверов NVIDIA - тут выбираешь и скачиваешь соответствующий драйвер. После загрузки запускаешь как exe. файл.
зайди сюда NVIDIA - драйверы -
там нажми :)
скачай и установи.
вот только обновка драйвера не поможет автору ниразу.
Стас - а совместимости чего?
мирамакс - почему?
А почему должна помочь?
