TFTP сервер, не отправить и не скачать файл, error 32
borodinaries
27 Май 2016
Здравствуйте уважаемые форумчане! Не могу добиться успешной отправки или скачивания файла на, с TFTP сервера. Сервер запущен на windows 8.1, клиент на windows 7. Скриншоты прилагаю, спасибо!
    17.2 KB · Просмотры: 215
    60.2 KB · Просмотры: 330
    62.4 KB · Просмотры: 217
    48.8 KB · Просмотры: 188
    41.1 KB · Просмотры: 154
    45 KB · Просмотры: 147
    61.6 KB · Просмотры: 193
ошибка - error 32 исчезла, а проблема осталась.
лог TFTP-сервера:
Connection received from 192.168.1.3 on port 50144 [27/05 22:49:45.584]
Write request for file <copy.txt>. Mode netascii [27/05 22:49:45.584]
Using local port 58772 [27/05 22:49:45.584]
<copy.txt>: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [27/05 22:49:46.584]
Connection received from 192.168.1.3 on port 50144 [27/05 22:49:46.596]
Write request for file <copy.txt>. Mode netascii [27/05 22:49:46.597]
Using local port 58773 [27/05 22:49:46.597]
<copy.txt>: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [27/05 22:49:47.597]
Connection received from 192.168.1.3 on port 50144 [27/05 22:49:48.609]
Write request for file <copy.txt>. Mode netascii [27/05 22:49:48.609]
Using local port 58774 [27/05 22:49:48.609]
<copy.txt>: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [27/05 22:49:49.609]
Connection received from 192.168.1.3 on port 50144 [27/05 22:49:52.618]
Write request for file <copy.txt>. Mode netascii [27/05 22:49:52.618]
Using local port 58775 [27/05 22:49:52.618]
<copy.txt>: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [27/05 22:49:53.618]
Connection received from 192.168.1.3 on port 50144 [27/05 22:50:00.620]
Write request for file <copy.txt>. Mode netascii [27/05 22:50:00.620]
Using local port 58776 [27/05 22:50:00.621]
<copy.txt>: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [27/05 22:50:01.622]
Connection received from 192.168.1.3 on port 50144 [27/05 22:50:08.622]
Write request for file <copy.txt>. Mode netascii [27/05 22:50:08.623]
Using local port 58777 [27/05 22:50:08.623]
<copy.txt>: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [27/05 22:50:09.623]
Connection received from 192.168.1.3 on port 50144 [27/05 22:50:16.625]
Write request for file <copy.txt>. Mode netascii [27/05 22:50:16.626]
Using local port 58778 [27/05 22:50:16.626]
<copy.txt>: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [27/05 22:50:17.626]
Connection received from 192.168.1.3 on port 50144 [27/05 22:50:24.628]
Write request for file <copy.txt>. Mode netascii [27/05 22:50:24.628]
Using local port 58779 [27/05 22:50:24.628]
<copy.txt>: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [27/05 22:50:25.628]
Connection received from 192.168.1.3 on port 50144 [27/05 22:50:32.633]
Unexpected request 5 from peer [27/05 22:50:32.634]
Returning EBADOP to Peer [27/05 22:50:32.634]
Connection received from 192.168.1.3 on port 58397 [27/05 22:54:08.490]
Read request for file <okean.jpg>. Mode octet [27/05 22:54:08.491]
Using local port 49897 [27/05 22:54:08.750]
Connection received from 192.168.1.3 on port 58397 [27/05 22:54:09.485]
Read request for file <okean.jpg>. Mode octet [27/05 22:54:09.486]
Using local port 49898 [27/05 22:54:09.486]
Connection received from 192.168.1.3 on port 58397 [27/05 22:54:11.498]
Read request for file <okean.jpg>. Mode octet [27/05 22:54:11.498]
Using local port 49899 [27/05 22:54:11.498]
Connection received from 192.168.1.3 on port 58397 [27/05 22:54:15.509]
Read request for file <okean.jpg>. Mode octet [27/05 22:54:15.509]
Using local port 49900 [27/05 22:54:15.509]
Connection received from 192.168.1.3 on port 58397 [27/05 22:54:23.509]
Read request for file <okean.jpg>. Mode octet [27/05 22:54:23.509]
Using local port 49901 [27/05 22:54:23.510]
TIMEOUT waiting for Ack block #1 [27/05 22:54:23.751]
TIMEOUT waiting for Ack block #1 [27/05 22:54:24.487]
TIMEOUT waiting for Ack block #1 [27/05 22:54:26.500]
TIMEOUT waiting for Ack block #1 [27/05 22:54:30.510]
Connection received from 192.168.1.3 on port 58397 [27/05 22:54:31.515]
Read request for file <okean.jpg>. Mode octet [27/05 22:54:31.515]
Using local port 49902 [27/05 22:54:31.515]
TIMEOUT waiting for Ack block #1 [27/05 22:54:38.511]
Connection received from 192.168.1.3 on port 58397 [27/05 22:54:39.515]
Read request for file <okean.jpg>. Mode octet [27/05 22:54:39.516]
Using local port 60910 [27/05 22:54:39.516]
TIMEOUT waiting for Ack block #1 [27/05 22:54:46.516]
Connection received from 192.168.1.3 on port 58397 [27/05 22:54:47.519]
Read request for file <okean.jpg>. Mode octet [27/05 22:54:47.519]
Using local port 60911 [27/05 22:54:47.519]
TIMEOUT waiting for Ack block #1 [27/05 22:54:54.517]
Connection received from 192.168.1.3 on port 58397 [27/05 22:54:55.528]
Unexpected request 5 from peer [27/05 22:54:55.528]
Returning EBADOP to Peer [27/05 22:54:55.528]
TIMEOUT waiting for Ack block #1 [27/05 22:55:02.519]
Добрые люди, извиняйте за беспокойство, проблема решена! Возникла она по своей невнимательности или незнанию, что по умолчанию в windows7 в правилах брандмауэра нет правила для TFTP и надо просто его создать. Спасибо!
    40.4 KB · Просмотры: 445
    44.9 KB · Просмотры: 741
