Установка AMD Athlon XP 2500+ на мать с 462 сокетом
  • Автор темы Автор темы SQD
SQD
18 Янв 2009
здравствуйте
есть старая мать Socket 462 (ещё PCPartner'овская), на неё нужен проц. на примете есть AMD Athlon XP 2500+ - L2- 512 KB. подойдёт ли? какую инфу нужно знать о матери и о проце, чтоб понять совместимы ли они?..
вот описание проца
CPU Information
Get HTML code
General information
Type CPU / Microprocessor
Family AMD Athlon XP
Part number AXDA2500DKV4D
Stepping codes AQUCA AQXCA AQXDA AQXEA AQXFA AQYFA AQYHA AQZEA AQZFA IQYFA KQYHA KQZFA PQZFA
Frequency (MHz) 2500 (rated)
1833 (real)
Bus speed (MHz) 333
Clock multiplier 11
Package 453-pin organic PGA
1.95" x 1.95" (4.95 cm x 4.95 cm)
Socket Socket A (Socket 462)
Architecture / Microarchitecture
Processor core Barton (Model 10)
Manufacturing process 0.13 micron copper process
Floating Point Unit Integrated
Level 1 cache size 64 KB code
64 KB data
Level 2 cache size Full-speed exclusive on-die 512 KB
Features MMX technology
SSE
3DNow! Professional
Low power features Halt state
Stop Grant states
Sleep state
Probe state
Electrical/Thermal parameters
V core (V) 1.65
Min/Max operating temperature (°C) 0 - 85
Typical/Max power dissipation (W) 53.7 / 68.3
Notes on AMD AXDA2500DKV4D
Actual bus frequency is 166 MHz. Because the processor uses Double Data Rate bus the effective bus speed is 333 MHz.
описание матери
Chipset
VIA® KT266/KT266A
Processor
Full supports АМО Athlon™ and DurопТМ processors use Socket А.
Supports bus speed of 100/133MHz processors.
VRM 9.0 (Voltage Regulator Modules) оп Board
FlexibIe motherboard design with оп board VRM 9.0.
System Memory
А total of two 184pin DDR SDRAM sockets.
Supports 4 banks up to 2GB DRAMs (512МЬ х8/х16 ОММ technology) for register and unbuffered DDR SDRAM module.
Supports DDR SDRAM тетогу types.
Mixed 1М 12М 14М 18М 116М 132М 164М х N DRAMs. 2.5V ОММ inteгface foг DDR SDRAM.
SystemBIOS
РпР, АРМ, АТАРI and Windows 95/98. Full supportof АСР' & DMI.
Auto detects and supports LBA harddisk with capacities оуег 804GB. Easy to upgrade BIOS Ьу end user.
On-board I/0
Оп board two РСI fast IDЕ ports supporting up to 4 АТА, АТА2 and Ultra ОМА33/66/100 IDЕ devices.
Support Bus Master IDЕ. РIO mode 4 (up to 16.6М bytes/sec) and Ultra ОМА33/66/100 (up to 33/66/100М bytes/sec) transfer.
Опе ECP/EPP parallel port.
Two 16550 CompatibIe UART serial ports.
Опе floppy port supports two FDD of 360КВ, 720КВ, 1.2МВ ,1.44МВ and 2.88МВ capacity.
Six USB ports (four ports via two headers). PS/2 mouse is supported.
PS/2 keyboard is supported.
Infrared (IrDA) is supported via а header.
Опе Line/speaker out, опе Mic in, опе line in and MlDllGameport (optional). Опе Front Рапе' Sound Connector (via а header).
Plug-and-Play
Supports Plug and Play specification 1.1.
Plug and Play for DOS, Windows® 3.Х, Windows® 95 as well as Windows® 98.
Fully steerabIe РСI interгupts.
Full Featured Aeeelerated Graphies Port (AGP)
AGP у2.0 compliant.
Fast Ethernet Interfaee (optional)
High performance PCI master interface with scatter / gather and bursting capability.
Standard ACR connector to extemal PHYceiver. 10/100MHz full and half duplex operation.
On-board SoundBlaster Pro Hardware and Direet Sound Ready АС97 Digital Audio
Dual full-duplex Direct Sound channels between system тетогу and АС97 link.
РСI master interface with scatter / gather and bursting capability. Host based sample rate сопуегtег and mixer.
Hardware SoundBlaster Рго for Windows DOS Ьох and real-mode DOS legacy compatibility.
Complete software driver suppoгt for Windows-95, Windows-98 and Wiпdоws-Nт.
Power Management
Suppoгts SMM, АРМ and ACPI.
Break switch for instant suspend/resume оп system operations. Energy star "Green РС" compliant.
WOL (Wake-On-Lan) header suppoгt.
External modem Ring-in Wake-up suppoгt.
Expansion Slots
1 AGP slot (AGP 2.0 compliant).
1 Advanced Communication Riser (ACR) slot.
2 РСI bus master slots - уег. 2.1 compliant.
На сайте производителя материнки должны быть указаны поддерживаемые процессоры. Даже в описании товара на Яндекс-маркетет это указано. Вообще не проблема.
спасибо.
1) PCPartner как производителя уже не существует
2) если не проблема, почему сам не указал?
Походу не пойдет
