что то с компом.вдруг всё пропадает и появляется надпись
A problem has been detected and windows has been shut down to prevent damage to your computer.
If this is the first time you`ve seen this stop error screen appears again follow these steps: chek to make sure any new hardware of software is poperly installed.
If this is a new installation, ask yoree hardware of software manufacturer for any windows updater you might need.
If problems continue,disable or remove any newly installed hordware or software.Disable BIOS memory options such as caching of shadowing.If you need to use safe mode to remowe or disable components, press F8 to select advanced startup options , and then select safe mode.
stop:0x0000000a
(0x000000E8 ,0x00000002 ,0x00000001 ,0x80702A16)
Begining damp of physical memory.Physical memory dump complete.
or technical support group for fortner assistans.
что всё это значит?уже несколько раз такое вылезало.что делать?
stop:0x0000000a
