Ошибка при получении даных из SQL
не могу понять что за ошибка
кодировки везде правильно стоят
запись работает
но на строчке rdr = cmd.ExecuteReader(); выскакивает ошибка
Гугл не помог ((
Код:
using System.Collections;
using System.Collections.Generic;
using UnityEngine;
using System.IO;
using MySql.Data.MySqlClient;
using MySql.Data;
using System.Runtime;
using System;
using System.Data;
public class tst : MonoBehaviour
string constr = "Server=localhost;Database=testunity8;User ID=root;Password=root;CharSet=utf8;port=3306";
MySqlConnection con = null;
// command object "Server=localhost;Database=easychild;User ID=root;Password=root;Pooling=true"
MySqlCommand cmd = null;
// reader object
MySqlDataReader rdr = null;
// Start is called before the first frame update
void Awake()
con = new MySqlConnection(constr);
con.Open();
Debug.Log("Connection State: " + con.State);
void OnApplicationQuit()
if (con != null)
if (con.State.ToString() != "Closed")
con.Close();
con.Dispose();
Debug.Log("killing con");
public void loadData()
string query = "SELECT * FROM test;";
try
if (con.State.ToString() != "Open")
con.Open();
using (cmd = new MySqlCommand(query, con))
if (rdr.HasRows)
while (rdr.Read())
Debug.Log(rdr[1]);
rdr.Dispose();
catch (Exception ex)
Debug.Log(ex.ToString());
error:
MySql.Data.MySqlClient.MySqlException (0x80004005): Fatal error encountered attempting to read the resultset. ---> MySql.Data.MySqlClient.MySqlException (0x80004005): Expected end of data packet
at MySql.Data.MySqlClient.NativeDriver.CheckEOF () [0x00017] in <326e9aab93854e739606c3572c385a34>:0
at MySql.Data.MySqlClient.NativeDriver.ReadEOF () [0x00011] in <326e9aab93854e739606c3572c385a34>:0
at MySql.Data.MySqlClient.NativeDriver.GetColumnsData (MySql.Data.MySqlClient.MySqlField[] columns) [0x00017] in <326e9aab93854e739606c3572c385a34>:0
at MySql.Data.MySqlClient.Driver.GetColumns (System.Int32 count) [0x0001c] in <326e9aab93854e739606c3572c385a34>:0
at MySql.Data.MySqlClient.ResultSet.LoadColumns (System.Int32 numCols) [0x00000] in <326e9aab93854e739606c3572c385a34>:0
at MySql.Data.MySqlClient.ResultSet..ctor (MySql.Data.MySqlClient.Driver d, System.Int32 statementId, System.Int32 numCols) [0x00029] in <326e9aab93854e739606c3572c385a34>:0
at MySql.Data.MySqlClient.Driver.NextResult (System.Int32 statementId) [0x00035] in <326e9aab93854e739606c3572c385a34>:0
at MySql.Data.MySqlClient.MySqlDataReader.NextResult () [0x00053] in <326e9aab93854e739606c3572c385a34>:0
at MySql.Data.MySqlClient.MySqlDataReader.NextResult () [0x00116] in <326e9aab93854e739606c3572c385a34>:0
at MySql.Data.MySqlClient.MySqlDataReader.Close () [0x00052] in <326e9aab93854e739606c3572c385a34>:0
at MySql.Data.MySqlClient.MySqlCommand.ResetReader () [0x00020] in <326e9aab93854e739606c3572c385a34>:0
at MySql.Data.MySqlClient.MySqlCommand.ExecuteReader (System.Data.CommandBehavior behavior) [0x002d1] in <326e9aab93854e739606c3572c385a34>:0
at MySql.Data.MySqlClient.MySqlCommand.ExecuteReader () [0x00000] in <326e9aab93854e739606c3572c385a34>:0
at (wrapper remoting-invoke-with-check) MySql.Data.MySqlClient.MySqlCommand.ExecuteReader()
at Join.loadData () [0x0005d] in C:\Users\tim\Documents\UnityProject\EasyChild\Assets\script\sqlLoginJoin\Join.cs:77
UnityEngine.Debug:Log(Object)
Join:loadData() (at Assets/script/sqlLoginJoin/Join.cs:90)
запись работает
Гугл не помог ((
Код:
using UnityEngine;
using System.IO;
using MySql.Data;
using System;
using System.Data;
// reader object
void Awake()
con.Open();
if (con != null)
con.Close();
con.Dispose();
try
con.Open();
if (rdr.HasRows)
while (rdr.Read())
Debug.Log(rdr[1]);
rdr.Dispose();
error:
