[Tue May 14 11:16:58 2013] [warn] Init: Session Cache is not configured [hint: SSLSessionCache]
[Tue May 14 11:16:58 2013] [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Tue May 14 11:16:58 2013] [warn] RSA server certificate CommonName (CN) `eBox Server' does NOT match server name!?
[Tue May 14 11:17:04 2013] [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Tue May 14 11:17:04 2013] [warn] RSA server certificate CommonName (CN) `eBox Server' does NOT match server name!?
[Tue May 14 11:17:04 2013] [notice] Apache/2.2.22 (Ubuntu) mod_ssl/2.2.22 OpenSSL/1.0.1 mod_perl/2.0.5 Perl/v5.14.2 configured -- resuming normal operations
Wide character in print at /usr/share/perl5/Log/Dispatch/File.pm line 141.
[Tue May 14 11:22:48 2013] [notice] caught SIGTERM, shutting down
[Tue May 14 11:45:19 2013] [warn] Init: Session Cache is not configured [hint: SSLSessionCache]
[Tue May 14 11:45:20 2013] [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Tue May 14 11:45:20 2013] [warn] RSA server certificate CommonName (CN) `eBox Server' does NOT match server name!?
[Tue May 14 11:45:24 2013] [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Tue May 14 11:45:24 2013] [warn] RSA server certificate CommonName (CN) `eBox Server' does NOT match server name!?
[Tue May 14 11:45:24 2013] [notice] Apache/2.2.22 (Ubuntu) mod_ssl/2.2.22 OpenSSL/1.0.1 mod_perl/2.0.5 Perl/v5.14.2 configured -- resuming normal operations
[Tue May 14 11:46:17 2013] [error] server reached MaxClients setting, consider raising the MaxClients setting
Trace begun at /usr/share/zentyal/cgi/captiveportal.cgi line 45
ModPerl::ROOT::ModPerl::Registry::usr_share_zentyal_cgi_captiveportal_2ecgi::__ANON__('Error::Simple=HASH(0xba1bbad0)', 'SCALAR(0xba072098)') called at /usr/share/perl5/Error.pm line 375
eval {...} at /usr/share/perl5/Error.pm line 365
Error::subs::run_clauses('HASH(0xba1907b4)', 'Error::Simple=HASH(0xba1bbad0)', undef, 'ARRAY(0xba072354)') called at /usr/share/perl5/Error.pm line 427
Error::subs::try('CODE(0xba182cdc)', 'HASH(0xba1907b4)') called at /usr/share/zentyal/cgi/captiveportal.cgi line 125
ModPerl::ROOT::ModPerl::Registry::usr_share_zentyal_cgi_captiveportal_2ecgi::handler('Apache2::RequestRec=SCALAR(0xba10ecb8)') called at /usr/lib/perl5/ModPerl/RegistryCooker.pm line 204
eval {...} at /usr/lib/perl5/ModPerl/RegistryCooker.pm line 204
ModPerl::RegistryCooker::run('ModPerl::Registry=HASH(0xba10edf8)') called at /usr/lib/perl5/ModPerl/RegistryCooker.pm line 170
ModPerl::RegistryCooker::default_handler('ModPerl::Registry=HASH(0xba10edf8)') called at /usr/lib/perl5/ModPerl/Registry.pm line 31
ModPerl::Registry::handler('ModPerl::Registry', 'Apache2::RequestRec=SCALAR(0xba10ecb8)') called at -e line 0
eval {...} at -e line 0
$VAR1 = bless( {
'-file' => '/usr/share/perl5/EBox/Config/Redis.pm',
'-text' => 'read_file \'/var/lib/zentyal-captiveportal/conf/redis.passwd\' - sysopen: No such file or directory',
'-line' => '586',
'-package' => 'Error'
}, 'Error::Simple' );
ModPerl::ROOT::ModPerl::Registry::usr_share_zentyal_cgi_captiveportal_2ecgi::__ANON__('Error::Simple=HASH(0xba1bbb5c)', 'SCALAR(0xba072098)') called at /usr/share/perl5/Error.pm line 375
Error::subs::run_clauses('HASH(0xba1907c0)', 'Error::Simple=HASH(0xba1bbb5c)', undef, 'ARRAY(0xba072354)') called at /usr/share/perl5/Error.pm line 427
Error::subs::try('CODE(0xba182cf0)', 'HASH(0xba1907c0)') called at /usr/share/zentyal/cgi/captiveportal.cgi line 125
ModPerl::ROOT::ModPerl::Registry::usr_share_zentyal_cgi_captiveportal_2ecgi::handler('Apache2::RequestRec=SCALAR(0xba10eccc)') called at /usr/lib/perl5/ModPerl/RegistryCooker.pm line 204
ModPerl::RegistryCooker::run('ModPerl::Registry=HASH(0xba10ee0c)') called at /usr/lib/perl5/ModPerl/RegistryCooker.pm line 170
ModPerl::RegistryCooker::default_handler('ModPerl::Registry=HASH(0xba10ee0c)') called at /usr/lib/perl5/ModPerl/Registry.pm line 31
ModPerl::Registry::handler('ModPerl::Registry', 'Apache2::RequestRec=SCALAR(0xba10eccc)') called at -e line 0
$VAR1 = bless( {
'-line' => '586',
