Совместимость памяти PC3200 400MHz 512MB
Извиняюсь(если мой вопрос был задан-некоректно,т.к. ответа на него небыло.),задам по другому. Вот данные моего Процессора,Матери и Планок памяти:
--------[ CPU ]---------------------------------------------------------------------------------------------------------
CPU Properties:
CPU Type Intel Celeron-S, 1200 MHz (12 x 100)
CPU Alias Tualatin, A80530
CPU Stepping tA1
Instruction Set x86, MMX, SSE
Original Clock 1200 MHz
L1 Code Cache 16 KB
L1 Data Cache 16 KB
L2 Cache 256 KB (On-Die, ATC, Full-Speed)
CPU Physical Info:
Package Type 370 Pin FC-PGA2
Package Size 4.95 cm x 4.95 cm
Transistors 44 million
Process Technology 6M, 0.13 um, CMOS
Die Size 80 mm2
Core Voltage 1.475 / 1.5 V
I/O Voltage 3.3 V
Typical Power 20 / 21 W @ 1.20 GHz
Maximum Power 29.9 / 32.1 W @ 1.20 GHz
--------[ Motherboard ]-------------------------------------------------------------------------------------------------
Motherboard Properties:
Motherboard ID 10/09/2001-i815-47B27X-IA69RT3CC-00
Motherboard Name Chaintech 6OIA3T
Front Side Bus Properties:
Bus Type Intel GTL+
Bus Width 64-bit
Real Clock 100 MHz
Effective Clock 100 MHz
Bandwidth 800 MB/s
Memory Bus Properties:
Bus Type SDR SDRAM
Bus Width 64-bit
Chipset Bus Properties:
Bus Type Intel Hub Interface
Bus Width 8-bit
Motherboard Physical Info:
CPU Sockets/Slots 1
Expansion Slots 3 PCI, 1 AGP, 1 CNR
RAM Slots 2 DIMM
Integrated Devices Audio
Form Factor Micro ATX
Motherboard Size 190 mm x 240 mm
Motherboard Chipset i815EP
--------[ SPD ]---------------------------------------------------------------------------------------------------------
[ DIMM1: SpecTek (128 MB PC133 SDRAM) ]
Memory Module Properties:
Module Name SpecTek
Serial Number None
Module Size 128 MB (1 rank, 4 banks)
Module Type Unbuffered
Memory Type SDRAM
Memory Speed PC133 (133 MHz)
Module Width 64 bit
Module Voltage LVTTL
Error Detection Method None
Refresh Rate Reduced (7.8 us)
Memory Timings:
@ 133 MHz 3.0-3-3-6 (CL-RCD-RP-RAS)
@ 83 MHz 2.0-2-2-4 (CL-RCD-RP-RAS)
Так вот-могу ли я на свой комп поставить планку PC3200 400MHz 512MB - взамен своих двух по 128MB?
Жду ответа от знающих людей,заранее Благодарен(и прошу Извинить за мою неопытность.)
CPU Properties:
CPU Stepping tA1
L1 Code Cache 16 KB
L1 Data Cache 16 KB
CPU Physical Info:
Die Size 80 mm2
I/O Voltage 3.3 V
Bus Type Intel GTL+
Bus Width 64-bit
Real Clock 100 MHz
Bandwidth 800 MB/s
Bus Type SDR SDRAM
Bus Width 64-bit
Bus Width 8-bit
CPU Sockets/Slots 1
RAM Slots 2 DIMM
Module Name SpecTek
Serial Number None
Memory Type SDRAM
Module Width 64 bit
Memory Timings:
