Проблема с загрузкой компьютера
Я не профессионал и техническим языком не владею но проблема такая:
При включении ноутбука тошиба сателит л650 идет нормальная загрузка виндовс потом появляется на доли секунд рабочий стол а после выскакивает синий экран и вот такая надпись:
a problem has been detected and windows has been shut down to prevent damage to your computer.
irql-not-less-or-equal
if this is the first time you seen this stop error screen,restart your computer .if this screen appears again ,follow these steps:
check to make sure any new hardware or software is properly installed.
if this is a new installation , ask your hardware or software manufacturer
for any windows updates you might need.
if problems continue,disable or remove any newly installed hardware or software.
disable bios memory options such as caching or shadowing.
if you need to use safe mode to remove or disable components ,restart
your computer,press f8 to select advanced startup options, and then
select safe mode.
technical information:
***stop: 0x0000000A (0xFFFFFFEO, 0x00000002, 0x00000000, 0x80537434)
beginning dump of physical memory
physical memory dump complete.
contact your system administrator or technical support group for further
assistance.
Если сможете ответить ---заранее спасибо!!!
select safe mode.
assistance.
