Прошивка Nokia C2-01 RM-721
  • Автор темы Автор темы Demonik
Demonik
AVE Tehnari
16 Май 2011
имеем этот кирпичик
имеем Phoenix Service Software 2012.24.000.48366
имеем прошивку скачал с http://allnokia.ru/firmware/c2-01.htm
тел компом видится
тел шьётся в dead mode
прошивка доходит до конца но тел отрубается и не проходит проверку как я понял, куда копать?
вот лог
Flashing started
Creating product data items list
Product data items list created
Backup not required
Flashing phone
Initializing
Scanning image files...
Waiting for USB device...
Loading secondary boot code: 15168 bytes
Secondary boot loaded
BB Asic Index is: 00
Asic ID is: 000000030000022600010007600C192102031104
EM Asic ID is: 00000C35
EM Asic ID is: 00000C30
Public ID is: 19D00015F9D80344CC99C73796877726C296F05E
Asic Mode ID: 00
Hash: 916F75217F32081248B15C38DFC8E81B
ROM ID: E693EF0DAC22615B
Device type is: 05
Device Index is: 00
Manufacturer code: 0000
Device ID: 0000
Extended device ID: 0000
Revision ID: 0000
Device type is: 04
Device Index is: 00
Manufacturer code: FFFF
Device ID: 0000
Revision ID: 0000
Device type is: 00
Device Index is: 00
Manufacturer code: 0020
Device ID: 0040
Revision ID: 0031
Device type is: 00
Device Index is: 01
Device ID: 0001
Revision ID: 0000
Device type is: 03
Device Index is: 00
Device ID: 0040
Revision ID: 0031
Loading update server code: 869872 bytes
Update server loaded
Asic CMT: Start programming 53936 KB...
Asic CMT: Programming data sent: 0%
Asic CMT: Programming data sent: 10%
Asic CMT: Programming data sent: 20%
Asic CMT: Programming data sent: 30%
Asic CMT: Programming data sent: 40%
Asic CMT: Programming data sent: 50%
Asic CMT: Programming data sent: 60%
Asic CMT: Programming data sent: 70%
Asic CMT: Programming data sent: 80%
Asic CMT: Programming data sent: 90%
Asic CMT: Programming data sent: 100%
Programming complete
Asic CMT: Verifying communication to device...
Waiting for communication response: 25
Waiting for communication response: 24
Waiting for communication response: 23
Waiting for communication response: 22
Waiting for communication response: 21
Waiting for communication response: 20
Waiting for communication response: 19
Waiting for communication response: 18
Waiting for communication response: 17
Waiting for communication response: 16
Waiting for communication response: 15
Waiting for communication response: 14
Waiting for communication response: 13
Waiting for communication response: 12
Waiting for communication response: 11
Waiting for communication response: 10
Waiting for communication response: 9
Waiting for communication response: 8
Waiting for communication response: 7
Waiting for communication response: 6
Waiting for communication response: 5
Waiting for communication response: 4
Waiting for communication response: 3
Error 0x8401F121 communicating to phone. Unable to verify comm.
Warning: Unable to communicate to product after flashing
Starting to recover the phone
Recovering phone
Initializing
Phone recovery completed. Waiting for phone to boot up
Bootup successful
Verifying communication to product (before flash finalizing)
Communication verified
All operations completed
Firmware updating failed.
Дим, попробуй феникс по старее, новые глючные собаки... (желательно феникс с phone browser на борту, эти по стабильнее). и еще, проша случайно не ниже уже влитой версии?
А для чего прошивали? Может проблеммы с железом? Он же в конце пишет что теряет связь с телефоном и потом восстанавливает старую пршивку, попробуйте другие версии проошивки, если не поможет то думаю только внутрисхемное:D
спасибо, попробую.
прошивался потому что начал глючить звук, трубка брата, он рассказывал что, его не слышат, сначала этот баг проявлялся 1 раз в месяц, потом всё чаще и чаще.
WOLF Project там стояла совсем старая версия прошивки.
Weles кстати пробовал несколько раз и теряет трубку феник именно в одно и тоже время, лог одинаков, пробовал раз пять.
Попробуй всё таки поискать другие версии прошивки, мало-ли.
поставил более старый феник, но в open product нет моего RM-721, пришлось ставить снова новый.
скачал прошивки более ранние, пробую но поведение пока тоже самое
в конце теряет тел
я его выключаю снова, он снова появляется в системе, феник подхватывает его начинает проверять и выдаёт вот такую ошибку
лог
Flashing started
Backup not required
Flashing phone
Initializing
Asic Mode ID: 00
Device type is: 05
Device Index is: 00
Device ID: 0000
Revision ID: 0000
Device type is: 04
Device Index is: 00
Device ID: 0000
Revision ID: 0000
Device type is: 00
Device Index is: 00
Device ID: 0040
Revision ID: 0031
Device type is: 00
Device Index is: 01
Device ID: 0001
Revision ID: 0000
Device type is: 03
Device Index is: 00
Device ID: 0040
Revision ID: 0031
Asic CMT: Start programming 53888 KB...
Recovering phone
Initializing
Bootup successful
Failed to verfy communication to product
    11.8 KB · Просмотры: 240
кстати когда
телефон подключен и в диспетчере устройств видится
прошивал более старой 11,20
вчера пробовал 11,40
результат одинаковый
Если вы понизили версию прошивки то прямая дорога в сервис. халявным фениксом уже не подымите.
Дим, если ядро понизить этому телу, то ему кирдык...
ЗЫ
Попробуй прошиваться на чистой системе, где нет ни Нокия сюте, ни других аналогичных пакетов... (так же не помешает сменить флэш дрова и сборку проши.)
Попробуй перевести тело в Local Mode
И этоtehno004
И это все бесполезно.
в первый раз шил, я не мог понизить, т.к. шился последней 11,40 версией, а тебе стояла вообще древняя, по-моему 11,20
Сначала не видел этого сообщения. Звук не может глючить из за прошивки Это 100% железная проблема была.
вот когда возился с прошивкой своей Nokia N81 RM-179 (8 гигов)-была та же фигня,причиной тому-железо непринимает прошивку...
решилось прошивкой на RM-223 (обычный телефон)!
так что Дим если есть другие RM на этот телефон-то попробуй...
я ж написал если под этот аппарат есть другая RM то можно попробовать....
А лучше не пробывать, с прошивками на телефонах нокиа лучше не баловаться, в худшем случае слетят сертификаты - тогда прямая дорога в сервис, в лучшем случае ничего не изменится.
проблема железная была 100% микрофон надо было смотреть. как показывает практика прошивка в 70% случаях глючит в одном и том же месте с соблюдением определенных условий (нажатием определенных кнопок запуском приложений и тп.) проблема появляющаяся в разных случаях при разных обстоятельствах 100% по железу
