Синий экран при работе IceSword
  • Автор темы Автор темы IDen
IDen
3 Июн 2010
Вот решил проверить систему на руткиты )))
Но при запуске программы тут же вылазит синий экран со следующим содержимым:
Код:
A problem has been detected and Windows has been shut down to prevent damage to your computer.
IRQL_NOT_LESS_OR_EQUAL
if this Is the first time you've seen this stop error screen, restartt your computer. If this screen appeajs again, ffollow these steps:
check to make sure any new hardware or software is properly Installed.
If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.
If problems continue, disable or remove any newlу installed hardware or software. Disable Bios memory options such as caching or shadowing.
if you need to use safe Mode to remove or disable components, restart your computer, press F8 to select  Advanced Startup options, and then select safe Mode.
Technical Information:
*** STOP: 0x0000000A (0x00000000, 0x00000002, 0x00000000, 0x804F8AAA)
Beginning dump of physical memory Dumping physical memory to disk:     1
Скрин прилагается http://exfile.ru/131721
Что делать?
