У меня возникла проблема : при загрузки Windows Xp на компьютер .. а именно когда появляется надпись приветствие компьютер выводит следующую надпись:
Problem has been detected and windows has been shut down to prevent damage your computer.
this is the first time you've seen this stop error screen,
start your computer.If this screen appears again.follow use steps:
back to make sure any new hardware or soft make is properly installed
this is a new installation . ask your hardware or software manufacture any window updates you might need
problems continue,disable or remove any newly installed hardware software.
Disable BIOS memory options such as caching or shadowing. you need to use safe mode to remove or disable components,restar you computer press F8 to select Advanced Startup Options and then ect safe mode:
Techical information:
stop: 0x000000D1 (0X00000000,0x00000002,0x00000000,0x00000000)
Beginning dump of physical memory
memory dump complete
