Усилитель 700 Вт, нужна помощь
Technical parameters:
8Ω: 1200W output power
4Ω: 2400W
Frequency response: +0 dB/-0.8dB (20Hz ~ 20KHz)
The total harmonic distortion: <0.5% 8Ω 20Hz ~ 20KHz
Signal-to-noise ratio: (20Hz - 20KHz): A weighted, full power output> 98dB
Instantaneous response of Bear: 25V/μS
The damping coefficient 8Ω: 10Hz-400Hz:> 200
Crosstalk between channels: 1kHz: -76 dB / 20kHz:-58dB
Input impedance: 20KΩ (Balanced) / 10KΩ (Unbalanced)
The input sensitivity: 1.25V/4Ω, rated power
This amp boardthe front level pushing transistor using one pair orignial C5200,A1943,output transistor using 10 pair original C5200,A1943.
The price include heatsink
